2
This discussion topic has been answered Discussion topic: sky Q box losing internet connection everytime its put into standby mode.
This message was authored by: starsky78
Every time i turn my sky Q box on after its been in standby mode overnight i have to put my wi-fi password in to connect to the internet,very annoying and started about 3 days ago.
Re: sky Q box losing internet connection everytime its put into standby mode.
Hi @starsky78
Hi @starsky78
Avatar for starsky78
Level 3 icon
This appears to have resolved the issue many thanks for your help.
