This discussion topic has been answered Discussion topic: SkyQ remote
Message posted on 01 Feb 2024 04:31 PM
We have a new SkyQ box and new remotes. We have previously used 2 remotes on the one box. We have managed to pair both remotes, but only the last one paired will work the SkyQ box. The first one paired will only change the volume. Can we get both to perform all functions.
Message posted on 01 Feb 2024 04:37 PM - last edited: 01 Feb 2024 04:39 PM
hi @PJS477
It can be doone but a little convoluted
You can only pair one in bluetooth mode but more than one can be paired in IR mode
First pair the one you want to use in Infrared mode
If necessary rest by pressing & holding 7 & 9 until the red led above the SKY Logo flashes 4 times
Then use the 1 & 3 to pair initially in bluetooth mode (make sure it has line of sight until paired) and pair with your TV
Then reset this remote to IR mode by pressing & holding 4 & 6
Then re-pair the one you want to use in bluetooth mode but don't perform the 4 & 6 step
hi @PJS477
Message posted on 01 Feb 2024 05:05 PM
Re: SkyQ remote
Many thanks.
