Discussion topic: SkyQ box says I have network connection issues. But I don't!
This message was authored by: SebWood
Trying to go to Apps or Sky Store, but the network connection prompt keeps coming up " it looks like you do not have Internet connection right now". But settings shows I am connected. I have reset 3 times, reset the Q box and turned on and off several times, but still no luck. Help please. Feels like a fault with the SkyQ box
Re: SkyQ box says I have network connection issues. But I don't!
Hi @SebWood
Was it a Network reset you have done?
Avatar for SebWood
I've tried all that and no difference. I'm not with Sky broadband but it says connected but I can't access Apps or Sky Store. It's a box fault, I think
Hi @SebWood
Have you rebooted your Router?
Avatar for SebWood
Yes a few times
