Discussion topic: Sky remote and sky box don’t seem to be working
Message posted on 17 Feb 2024 09:38 PM
Sky q box isn't working, the blue Q on the box isn't on and the remote control doesn't work
Message posted on 17 Feb 2024 09:43 PM
Re: Sky remote and sky box don’t seem to be working
Hi @Ama56
The blue Q only comes on when playing back a recording or after a reboot.
Try rebooting your Q box.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q box (Amber led).
If you had to press the button on the box to get it on then
Try completly resetting your Bluetooth remote.
