Discussion topic: SkyQ box lost internet
Message posted on 17 Dec 2023 08:04 PM
SkyQ box lost internet and can't reconnect. Also mini box stays in stand-by mode and won't turn on.
Message posted on 17 Dec 2023 08:29 PM
Re: SkyQ box lost internet
Hi @Fliptop001
Regarding lost internet.
Have you carried out a Network reset exactly as follows on the main Q box?
Regarding the mini not switching on.
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
