Discussion topic: Sky q 2 tb box keeps freezing and when you go to record or play a recorded program
This message was authored by: Paul2005
Sky q 2 tb box keeps freezing and when you go to record or play a recorded programme it says this programme can not be recorded. Then you have to reset the box and it's lasks about 1 hour before it does it again.
This message was authored by: AndySaunders
Re: Sky q 2 tb box keeps freezing and when you go to record or play a recorded program
We have been having very similar problems with the Sky Q box as well.
it started freezing and jumping. Then the apps have stopped working and then this evening there was no access to recordings.
This all seemed to start when Netflix changes happened back in November. We have called Sky now on numerous occasions and they keep asking us to reset the apps and the factory settings.
I am losing the will to live with Sky and their support.
Hi @Paul2005
Looks like the Hard drive may be failing.
Work through the following link.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
