1
This discussion topic has been answered Discussion topic: SkyQ. T
This message was authored by: Elderberry
SkyQ. T
Recording fine when wanting to watch the programme later it's taking a good ten mins to appear just has the circle going round seems to be taking longer each time
Re: SkyQ. T
@Elderberry
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Re: SkyQ. T
@Elderberry
Answered - Go to Answer
