Discussion topic: Sky
This message was authored by: James1208
Sky
Hi, Sky Q box has recently been running slow. Sometimes the picture freezes and then screen goes black. When in a recording it can freeze, not play or when you try to fast forward or rewind, it doesn't do anything, then jumps. At which point pressing the home button and stop button does not work. The 3 Sky Q mini boxes are also not working properly. Same as above and then says struggling to link with Sky Q box. Also the apps are not working smoothly, some won't load, some play and freeze all the time etc.
Internet is running fine as when switched to the actual Smart TV apps, they work not problem. Sky Q box shows network connected as ticked. Sky Q signal strength is 40 and the quality is 90. Not sure if the main Sky Q box which we have had for 8 years is in its way out.
Re: Sky
Hi @James1208
Try a Reset Settings in the main Q box hidden menu.
