Discussion topic: Sky won’t record
This message was authored by: Teresa3627
Sky won’t record
I have sky'Q and can't record anything and can't access my recordings
Re: Sky won’t record
@Teresa3627
Any error message displayed?
Have you tried rebooting the box?
If not, try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Teresa3627
Hi thanks for your reply and yes I've tried all of these and spent 15 minutes on the phone reconnecting my broadband and it's saying all connections are fine and everything is set up but it's still not letting me record or access recordings
