This discussion topic has been answered Discussion topic: Sky Q mini box not turn on
Message posted on 14 Jul 2023 11:13 AM
Hi my mini skyQ box will not turn on, cannot get a green light on the box
Message posted on 14 Jul 2023 12:20 PM
Hi @Barb125
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @Barb125
Message posted on 14 Jul 2023 12:40 PM
Re: Sky Q mini box not turn on
Many thanks it worked
Message posted on 11 Nov 2023 10:09 AM
After frustratingly mucking about with my mini box for about 20 mins your soultion helped instantly. Thankyou!👍
Message posted on 01 Sep 2024 08:55 AM
Have tried re paring the remote , it flashes as it should but box still shows red and won't go to green,
Message posted on 01 Sep 2024 08:56 AM
Also pressed the amber button on mini box will not turn green
