Discussion topic: Sky w box just packed up
This message was authored by: Vicky+Emberson
We were watching the tv through the box and the screen went off saying no signal . Have tried a second tv on the box but it still says no signal
Re: Sky w box just packed up
@Vicky+Emberson
A no signal message is usually connected to your TV whereas a no satellite signal may be a Sky Q box issue.
Avatar for Vicky+Emberson
Sky box packed up
@Vicky+Emberson  You're posting the same info, have you followed any of @Daniel0210  advise?
A No signal is a TV message, no satellite signal is a dish issue.  If no signal are you using the correct input on  the TV for the Sky Q box?
This message was authored by: twilight+princess
Check that the HDMI cable is still inserted into both the box & the TV. Also check that the TV is still on the AV/HDMI channel for the box.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
