Discussion topic: Sky w box just packed up
Message posted on 08 Jul 2023 04:50 PM
We were watching the tv through the box and the screen went off saying no signal . Have tried a second tv on the box but it still says no signal
Message posted on 08 Jul 2023 04:56 PM
Re: Sky w box just packed up
A no signal message is usually connected to your TV whereas a no satellite signal may be a Sky Q box issue.
Sky box packed up
Message posted on 08 Jul 2023 04:57 PM - last edited: 08 Jul 2023 04:59 PM
@Vicky+Emberson You're posting the same info, have you followed any of @Daniel0210 advise?
A No signal is a TV message, no satellite signal is a dish issue. If no signal are you using the correct input on the TV for the Sky Q box?
Message posted on 08 Jul 2023 05:31 PM
Check that the HDMI cable is still inserted into both the box & the TV. Also check that the TV is still on the AV/HDMI channel for the box.
I don’t work for Sky.
If I have helped then please leave a like.
