Discussion topic: Sky viewing card
Message posted on 15 Aug 2024 09:36 PM
Sky viewing card
Keep getting message "please ensure the correct viewing is inserted with the chip facing up"
I have taken card out put it back in. Correct way.
Unplugged skyq box and rebooted.
Still not resolved.
Message posted on 15 Aug 2024 09:46 PM
Re: Sky viewing card
Still not resolved.
Hi @SanjayK
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take out the card and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure it is completely dry and reinsert it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
