Discussion topic: Sky tv technical fault
This message was authored by: RubyPremji
Sky channels not working. Nothing recording. Message come sup stating fault with this channel. This channel is currently  affected by a problem with your satellite signal.
Re: Sky tv technical fault
Hi @RubyPremji   Try following the help pages. Do you have your own dish or is it a communial dish?
Sky TV no satellite signal | Sky Help | Sky.com | Sky Help | Sky.com
This message was authored by: RichardS11
Turned Sky on this morning no Sky TV at all Message saying no satalitte signal this is on every channel Live in North West
@RichardS11  Have you tried th steps in the post directly above yours?
Hi @RichardS11   The satellite does not care where you live, the signal footprint covers the entire UK.
I know that but there may be some local technical issue that is not letting the signal go up As you can see I am not the only one with this issue so something may be wrong somewhere
The only relevant 'local technical issue' is always between dish and box (or the box itself) : apart from that, 'local' has no meaning for satellite television broadcasting*.
Sky has many millions of satellite subscription households, so at any particular moment in time it's inevitable that some are having dish problems and post here.
*apart perhaps from really severe weather (intense rain/ice) in a particular region but that would only be transitory.
This message was authored by: Matt14482
Satellite issue on some channels
@Matt14482
If it's your own dish, you'll need to log a fault with Sky and book an installer visit to check the dish alignment.
This message was authored by: Nessa7
Hi no channels or recordings are playing says technical fault?
