Discussion topic: Sky tv not working
Message posted on 10 Jun 2023 06:47 PM
Sky tv not working
Wifi is working but tv box is not
Message posted on 10 Jun 2023 06:48 PM
Re: Sky tv not working
Please provide as much info as possible if you want help @Nasur
Message posted on 10 Jun 2023 07:18 PM
Hi @Nasur
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
