Discussion topic: Sky tv network connection
This message was authored by: Steve1703
Hi my Sky network connection keeps dropping and will not stay connected,I have reset many times it works for about 2-5 minutes the fails again
Re: Sky tv network connection
Hi @Steve1703
Are you carrying out a Network reset on your Q box to reset it?
Avatar for Steve1703
Hi yes I am
its ok for a few minutes then drops again
ive unplugged the qbox and even changed network sockets
still does the same thing 🤷‍♂️
@Steve1703 wrote:
Hi yes I am
Hi @Steve1703
Who is your Broadband supplier and how far is yourQ box from the router?
I am with BT
but the Qbox is hard wired
@Steve1703 wrote:
I am with BT
Has you disabled WiFi on the Q?
Nope
should I?
@Steve1703 wrote:
Nope
should I?
Hi @Steve1703
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router.  Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit...
If you have Q minis on WiFi then you have to leave the main box WiFi on.
