Discussion topic: Sky tv menu
This message was authored by: Turnercher_
Sky tv menu
Hi the tv sky menu is not working just keeps going round and round
Re: Sky tv menu
You have posted in the Sky Go forum. Is this a Sky Go issue or a TV service issue? if not Sky Go then which service do you subscribe to?
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Turnercher_
Re: Sky tv menu
I believe it is sky tv issue sky Q
Re: Sky tv menu
@Turnercher_  Your post has been moved to the correct board for Sky Q related issues.
Re: Sky tv menu
Thank you
Re: Sky tv menu
Have you powered it down and on again?
Re: Sky tv menu
Yes l have done it a couple of times
Re: Sky tv menu
I woild go through the box troubleshooter on the sky website. Chances are you'll end up at a replacement box. Keep your viewing card when they do the doorstep swap and make sure you have the right power cord as there are two types.
