Discussion topic: Sky tv box doesnt work
This message was authored by: Matt+De+Frate
No apps, recordings, etc... work - only tv channels.   Tried to restart twice to fix issue to no avail....
Re: Sky tv box doesnt work
Hi @Matt+De+Frate
