This discussion topic has been answered Discussion topic: Sky turning itself off
Message posted on 26 Jun 2024 06:55 PM
I've had this sky box for 12 months and the issue happened often in the first month or so, then was fine for ages but has just started happening again.
When watching live TV, or Netflix, or a recording (or anything!) the sky box turns itself off. Blank screen for about 15 seconds, then a message saying 'you will be ready to go in a couple of minutes, the screen will go blank, don't press any buttons. It then takes 3-5 minutes to restart.
It happened 6 times in half an hour last night, and twice so far this evening - annoying!
Any suggestions please?
Message posted on 26 Jun 2024 07:50 PM - last edited: 26 Jun 2024 07:51 PM
Hi @Kate991
Assume your Q box is well ventilated and not totally enclosed or stacked with other devices. In the current conditions it needs adequate ventilation due to the ambient high temperatures.
Q boxes can run warm but not so hot that you cannot easily bear your hand on them.
If you think it is OK and not overheating
Hi @Kate991
Message posted on 26 Jun 2024 08:57 PM
Re: Sky turning itself off
Thank you, most helpful. The box is in a normally closed cupboard, and it is pretty hot to touch. I will ventilate now!
Makes complete sense with how the weather was 12 months ago and now Thanks again.
Message posted on 15 Oct 2024 01:33 PM
Hi,
I am having a similar issue, I recently got a new Sky Q Box. Randomly my TV will turn blank with sound in the background. I have tried a new HDMI cable , reset the sky box. It seems that the new Sky box is bugging with the TV. Can anyone help?
Thanks!
Message posted on 26 Aug 2025 04:25 PM
My Sky Q box was only set up 7 days ago by a Sky Engineer after a house move when he fitted a new dish and checked the system. It has been turning itself off randomly for a while at the old house and now at the new house it is even worse - yesterday it happened at least 10 times during the day. When it turns off the TV comes up with No Signal message.
