6
This discussion topic has been answered Discussion topic: Sky test shows error, But !
This message was authored by: IanEA
Checking my system though SKY  service checker, it keeps telling me SKY Q box has a problem.,
everthing seems to be in order, all  is working ok, WiFi connected , picture ok, recording ok.
in fact nothing seems to be  wrong ? Checking Settings on TV. Everything is connected.
so why the recurrence fault message every time I check ?  I'am at a loss what to do .
sky help and BOT useless.
This message was authored by: stereohaven Answer
Re: Sky test shows error, But !
If you cannot see any problems with the service in daily use, I would ignore the service checker personally.
It's only really there for if you are experiencing an issue you can see, and then as a double check before getting in touch with Sky. The checker itself might have a fault but your products/service might not.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for IanEA
Level 2 icon
I believe you are absolutely right, the only fault is in SKYs  own service  checker.? Not a great help as a older non tech person.
Thank you for your imput.😃
Avatar for IanEA
Level 2 icon
Persistence Sky Q box problem :But there isn’t one
Sky keeps telling me I have a Sky Q box problem, but I have no idea why ,as , everything  is working perfectly , just did a reboot , but still get messages of fault.
The last thing I want   to do is a factory reset and lose all recordings and probably much else ? . Others seem to have this message.. suspicious turns to push  from Q to stream ploy?
there is no other lodgical reason to get this only  since  Sky announced  QBox discontinued .
sorry Sky sticking with Q to the end !
Re: Persistence Sky Q box problem :But there isn’t one
@IanEA
It hasn't been discontinued yet! It is still available to order or upgrade to but customers need to call as it's not available to order online.
Edit: I have moved this into the earlier thread you started.
@IanEA As has already been said if your box is working fine then ignore the message on the app.
Sky so far have never said Sky Q has been discontinued they have said they are saying you can no longer order it online but its still available by contacting Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for IanEA
Level 2 icon
I think your probably correct, but begs the question what's the point of a service check if it can't be relied on ? 🎄🎄🎄
