Discussion topic: Sky suddenly stops letting change channels
Message posted on 30 Jun 2025 10:25 PM
Sky suddenly stops allowing me to change channels and we have to restart the sky box for it to work. It's happened 3 times this week.
Message posted on 01 Jul 2025 10:45 AM
Re: Sky suddenly stops letting change channels
Hi @Lottie28
