Discussion topic: Sky q box needs resetting every morning
This message was authored by: Lynne25
Sky q box which is new will not switch on every morning and needs to be reset remove power cable then replacing it box then resets itself ok .Same issue next morning, I have switched off standby mode to NONE and smart standby to OFF in preferences,software updated. Any ideas please
Re: Sky q box needs resetting every morning
Hi @Lynne25
