Discussion topic: Sky start up
This message was authored by: davl
Sky start up
When i switch on tv it goes to samaung tv and i have to find sky icon and select to work. I have reset eveything, switched on and it is still no good. Also voice assistant is set to off but still speaks9
Re: Sky start up
@davl
That sounds like a setting on the Samsung TV, not the Sky box.
This message was authored by: cuke
Re: Sky start up
Try this:
  • Press the Settings button: on your Samsung remote (the gear icon).
  • Navigate to All Settings (or just Settings).
  • Go to the General tab.
  • Select Privacy & Security or Startup Screen (options vary by model).
  • Find the Startup Screen Option or Start Screen Option.
  • Disable: the setting for "Start with Smart Hub" or "Auto Smart Hub" and .Auto tvplus.
  • Enable: "Autorun Last App" (or "Use Last App") if available.
