Discussion topic: Sky shocking
This message was authored by: Laney6
Sky shocking
Yestaday Called up 2hr 4 people later to renew contract after 18 years subscription with them I needed new controls for normal box n multi room box
finally sorted and being sent only to cancel the order today
typical get u to sign and then pull out there part of the deal disgusting!
may cancel whole lot and go elsewhere
this is what u get after being a loyal paying customer for nearly 2 decades
Re: Sky shocking
@Laney6
Are you saying the arrangement for a new remote was cancelled?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Laney6
Re: Sky shocking
Yes they ordered and was on my app orders on my sky app to receive a message following day to say cancelled
I believe it was done so I would renew contract then backed out of there side of it following day
anything to get u to sign up
Re: Sky shocking
Doubt it since you can easily order a free replacement remote through the website troubleshooter anyway.
Re: Sky shocking
@Laney6
Unlikely to be related to renewal.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
The issue also may be because you've ordered two. It's very unlikely two remotes have become faulty at the same time.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
