Discussion topic: Sky remote
This message was authored by: Osagie1
Sky remote
Not working for sky mini but working on tv
Re: Sky remote
@Osagie1 try rebooting your mini box
if that doesnt help
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: DianeR1967
Re: Sky remote
How do I get a new sky q remote my buttons keep sticking and sometimes up and down button stop working
Re: Sky remote
@DianeR1967
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket.
Meanwhile, if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
