This discussion topic has been answered Discussion topic: Sky remote
Message posted on 21 Apr 2025 08:54 PM
Message posted on 21 Apr 2025 09:30 PM
@Itsonlyme33 wrote:
I had a new Sky remote about 3 months ago and it's been fine until about 3 hours ago when I couldn't increase/decrease the volume, although lately, it doesn't recognise voice commands either...this is why I originally had a new one. Everything else works except that...I tried 7 and 9 and 1 and 3 simultaneously but that hasn't worked as it says my LG tv can't be paired.?? I've also changed the batteries and rebooted.. .any suggestions please ?
Hi @Itsonlyme33
There should not be any reason why you cannot pair your remote to a LG TV.
With the Q box on with green led try completly resetting your Bluetooth remote again.
Use Find it for me in the LG TV set up instead of using Model ref.
Hi @Itsonlyme33
Message posted on 22 Apr 2025 08:20 AM
Re: Sky remote
Is there a soundbar or some other object that's blocking the view to your TV's IR receiver? I've had this same problem with my remote and LG TV. So try moving anything away from the IR input and see if that helps.
Pete.
