Discussion topic: No satellite signal
Message posted on 21 Apr 2025 05:28 PM
No satellite signal
My sky q is not getting any satellite signal. I have moved the main box and used a extension cable which I have used before with no problems. All connectors are fixed correctly
Message posted on 21 Apr 2025 05:32 PM
Re: No satellite signal
@She8
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 21 Apr 2025 05:38 PM
@She8 It might be worth carefully examining the ends of your coaxial cables for bent pins and stray strands of the outer screen shorting to the central pin.
Message posted on 22 Apr 2025 05:15 AM
Does it work if you take the extension cable out of the equation?
