Discussion topic: Sky remote
This message was authored by: Craig163
Sky remote
Tried the 7,9 button then 1,3 button reset to get on screen instructions to be able to use it for volume control. Nothing on screen and now the remote doesn't work at all. How do I get it back up and running
Re: Sky remote
After the 7 & 9 to reset you must make sure it has lne of sight of the IR receiver on the SKY Q box as it uses IR until you manage to re-pair it
