02 Dec 2023 07:44 PM
Good evening,
I cannot change channels using my Sky remote. I have changed batteries and rebooted a few times but still no joy.
Please advise
02 Dec 2023 07:47 PM
Posted by a Superuser, not a Sky employee. Find out moreWhich Sky TV platform - Sky+? SkyQ? Sky Glass/Stream?
02 Dec 2023 07:51 PM
Posted by a Superuser, not a Sky employee. Find out moreIf it's Sky streaming remote try these ideas:
Re-pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
02 Dec 2023 08:53 PM
SKY Q is the problem
15 Dec 2024 11:25 AM
What is the solution?
