11
This discussion topic is read only This discussion topic has been answered Discussion topic: Paramount+ not working on Sky Q
This message was authored by: MarkS1
My Sky Q box logs in to Paramount+ just fine, but when I select something to watch it just shows the lovely spinning circle.
Other apps (Disney etc) are working fine, and my Paramount account is fine as I can watch stuff on my laptop.  I've tried resetting the app cache, restarting the box etc but no luck.  I've been sitting waiting on the tech support chat for over an hour and nobody seems to be coming.  Any ideas?
Avatar for MarkS1
This message was authored by: MarkS1 Answer
Re: Paramount+ not working on Sky Q
So for no obvious reason it's started working again after a few months of not.  I guess some combination of things sorted it, shame we'll never know which 🙂
Locked
Hi @MarkS1
First thing to do is to check that the Q box is on the latest Software.
Home - settings - System info - Software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
If the software is up to date  there are two things you can try.
First is a Reset setting in the Q box hidden menu.
If you still have the issue then try refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Avatar for MarkS1
Thanks for the reply.  I've now tried all those.  Software did need updating, then I did a reset and an apps refresh.  Afer re-entering my Paramount+ account details, still got the same issue.  Other apps still OK.
Got a reply on the Sky chat, basically saying I need to contact Paramount which doesn't make much sense as I can watch content on my laptop
Hi @MarkS1   Apologies if I missed it, but you have you tried rebooting your broadband router to refresh its DNS.
Avatar for MarkS1
Yup, tried that.  I have a TP Link mesh network running from the router (means I can replace the router anytime without breaking anything in the house) but just to see I hardwired the Sky box direct to the router and no difference.  Sky now saying to contact Paramount (which I'm doing) but not convinced they'll be able to help
Avatar for MarkS1
This message was authored by: Smiddy
We have the same issue, tried all of the advice in this thread and it still isn't working. Called Sky this morning and have been advised to contact Paramount which we will do. Just wondering whether anyone has found anything else that might be causing the issue? Thanks.
This message was authored by: Jeffx99
I did all this (ok I didn't do the reset step) and it still wasn't working.
Left it a day, still no luck.
Turned the ad blocker off, now finally it works.
Ad blocker is off and it's still working.
I had a similar problem last year and I vaguely remember the problem is that the sign in expires - so signing out (which I did before all of the above) and back in again may be the magic step, just need to have the ad blocker off, it may be accessing a blocked DNS address.
This message was authored by: Siany+Williams
Turned ad blocking  off on my ubiquiti kit after totally resetting everything.
Fixed at last. Thank you for the solution!!!
This message was authored by: DDwarks
I'm not technically minded. How do I do the ad blocker step and where, please?
This message was authored by: Steeley
I recently solved this exact problem. I have pi-hole blocking advertisements. I had to disable pi-hole for the sky Q box and then paramount started working again
If you're not technically minded then you are unlikely to have an ad blocker. It's something geeky people like myself will turn on to try to block adverts
Locked
