Discussion topic: Sky remote not working
Message posted on 29 May 2025 02:16 PM
My sky remote voice settings has stopped working
Message posted on 29 May 2025 02:45 PM
							Re: Sky remote not working
Try resetting your broadband router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
