Discussion topic: On demand failure
Message posted on 28 May 2025 07:59 PM
On demand failure
Hi, why am I prevented from downloading content from on demand in standard definition.?
I carried out the usual checks mentioned elsewhere.
Is this a new strategy from sky to extract more money from existing customers?
Message posted on 28 May 2025 08:05 PM
Re: On demand failure
hi @tony3609
Have you changed your download preference to SD in
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Message posted on 28 May 2025 10:59 PM
Hi nigea99 yes I have ...makes no difference.
Message posted on 29 May 2025 02:59 AM - last edited: 29 May 2025 03:06 AM
I know you want to download in SD but do you have the HD add on? Is it asking you to upgrade?
We can potentially escalate your post to Sky. Sky will then try to refresh the viewing card which sometimes needs a couple of attempts. This link explains more:
https://www.sky.com/help/articles/call-to-upgrade-downloading-on-demand#q-help-articles
Message posted on 29 May 2025 01:30 PM
Hi Daniel0210 in the All Formats tab I have the choice to select HD or SD,
I select SD and return to content and select. I get message...Failed, No Subscription.
Message posted on 29 May 2025 02:27 PM
Hi @tony3609
you say.........
As posted by @nigea99
........ it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences. (Not in the all formats Tab)
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 29 May 2025 02:48 PM
Hi,Oldfella. Yes I changed download preferences to sd in home, settings, setup, preferences at an early stage of trying to find a solution.
