Discussion topic: Sky remote not working
Message posted on 10 Mar 2024 04:20 PM
Hello
My Sky remote seems not to be working. I have switched off at the wall, waited and have switched back on. This just seemed to suddenly stop working and I only realised once I tried to use the remote to change a channel, although it had been working previously. Please can you help as I cannot change channel, or do anything.
thank you
Message posted on 10 Mar 2024 04:21 PM
Re: Sky remote not working
@Angela455 wrote:
Hello
thank you
Hi @Angela455
Try completly resetting your Bluetooth remote.
Message posted on 10 Mar 2024 04:22 PM
However I can change channels using the up and down button, so it is not my battery
Message posted on 10 Mar 2024 04:33 PM
Hello
Yes I have just done this and 'Your Sky Q remote is now paired to your Sky Q box via Bluetooth', and the next step is to 'Continue', but my remote is not working to 'Continue'. When I press the middle button to continue, nothing is happening. It seems that only some of the buttons are working????
Message posted on 10 Mar 2024 04:41 PM
@Angela455 wrote:
Hello
Hi @Angela455
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
