Discussion topic: Sky remote is not working
This message was authored by: Pardeep1
Message posted on 20 Sep 2023 09:48 PM
Hi my sky tv remote is not working but I can change the volume with it
Find out more
Message posted on 20 Sep 2023 09:55 PM
Re: Sky remote is not working
Hi @Pardeep1
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
