Discussion topic: Sky Q mini
Message posted on 20 Sep 2023 03:03 PM
Sky Q mini
Hiya my mini box isn't working, I rang sky and they sent me a booster pack out but it still won't work.
when I go on my main sky box it says you do not have the required subscription to use sky Q mini box then I have the option to reactivate I do that and it still comes up with a cross at the side any ideas??
Message posted on 20 Sep 2023 03:17 PM
Re: Sky Q mini
Just to confirm you have a multiscreen subscription on your account?
Message posted on 20 Sep 2023 03:20 PM
Re: Sky Q mini
I wasn't told I havnt I've moved house so didn't plug it in upstairs straight away, when I came to do it it wouldn't work, I went over all the online stuff still nothing so I called sky he sent me out a booster pack I've plugged that in and it still doesn't work. But like I said on the main box it's saying I don't have the required subscription. I told him that's what it said when I called but he was adamant I needed this signal booster box thing.
Message posted on 20 Sep 2023 03:46 PM - last edited: 20 Sep 2023 03:46 PM
Re: Sky Q mini
Sounds like you were given the wrong advice. You need to pay for multiroom. Did you have it in the old house?
If not, how did you get the mini box?
Message posted on 20 Sep 2023 04:57 PM
Re: Sky Q mini
Yes I had it in my old house I moved and brought the boxes with an engineer came out to fit the internet and I said I would do the mini box when I was unpacked and sorted
Message posted on 20 Sep 2023 06:01 PM - last edited: 20 Sep 2023 06:03 PM
Re: Sky Q mini
Ok so your subscription shouldn't have changed. I would call Sky again, think they need to check your account.
Message posted on 20 Sep 2023 09:41 PM
Re: Sky Q mini
Will do thanks
