Discussion topic: Sky remote control
This message was authored by: Nabeelbegum
Sky remote control
Need a new smart remote control
Re: Sky remote control
@Nabeelbegum Try Amazon or contact Sky for a free replacement if it's still under warranty.
@Nabeelbegum
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
hi @Nabeelbegum
Not too sure what you mean by Smart remote control
If you mean voice control capable  - all new SKY Q remotes are Voice control capable and can be obtined from many sources.. You may be able to get a replacement for free by calling SKY
Note If you mean 'Touch' remote these are no longer available as they have not been produced for many years - although you might be able to pick up a 2nd hand one from the likes of ebay
@Anonymous
The remotes are loaned and I don't think a free replacement would not be dispatched based on how old it was.
