Discussion topic: Connecting sky mini-box to sky q
This message was authored by: Scott73
I cannot connect my old sky minibox to my new sky q box. Tried. All of the Suggested online help. How the hell do I get to speak to someone at sky
Re: Connecting sky mini-box to sky q
@Scott73 You ring 150 from a Sky Mobile or Sky Talk phone and wait for someone to answer your call.
Hi @Scott73
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
