Discussion topic: Sky q
This message was authored by: dbragg
Sky q
My sky q box freezes alot I've unplugged everything inc broadband still does it my WiFi is good has anyone else had the same problem it's driving me nuts yours steve
Re: Sky q
Hi @dbragg
Avatar for dbragg
Freezing
Hi my sky q mini box keeps freezing when watching it did get a reply from old fella but I've lost it can oldfella reply again or someone else sorry yours steve
Re: Freezing
@dbragg
I have merged your new post to the original.
Avatar for dbragg
Re: Sky q
Done all that my remote works i can hear sky but has a blue screen with circle going round and round saying please wait
Avatar for dbragg
Re: Sky q
I did everything you asked but it's still doing the same thing yours steve
Re: Sky q
Hi @dbragg
Have you tried rebooting your Q box since resetting the settings?
note: some features may take up to 5 minutes to return.Have you tried
