Discussion topic: Sky q
Message posted on 19 Dec 2025 08:12 PM
Sky q
My sky q mini box isn't working
Message posted on 19 Dec 2025 08:50 PM
Re: Sky q
Hi @Mich1981
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
