Discussion topic: Sky q
This message was authored by: AMT3
Sky q
Cannot connect sky q box to internet
Re: Sky q
Hi @AMT3
Avatar for AMT3
Re: Sky q
The only wps button I have is on the sky q box and it's not connecting when I press and hold it please help
Re: Sky q
@AMT3
WiFi Protected Set-up requires a button press on both the client device and the router: pressing only one button cannot work.
If you have a Sky Broadband Hub or Max Hub then the WPS button is cunningly concealed low down on the right hand edge where many users fail to spot it.
On a white Max Hub use only a short press, because a long press acts as a router reset.
