Discussion topic: Sky q
Message posted on 02 Nov 2024 08:50 PM
Sky q
My sky q will stop and no picture on the screen so I turn everything off and on then it works for 10 minutes then off again and I repeat
Message posted on 02 Nov 2024 09:42 PM
Re: Sky q
Hi @daniel1213
