Discussion topic: Sky q
This message was authored by: Beryl4
Sky q
My sky q box will not turn on
Re: Sky q
@Beryl4  Have you tried a power cycle turn off at mains for 5 minutes then restart
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
Re: Sky q
Hi @Beryl4
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
