Discussion topic: Sky q
Message posted on 09 Nov 2025 06:06 PM
Sky q
My sky q. Multi room is not working
Message posted on 09 Nov 2025 06:12 PM
Re: Sky q
Multiroom is a Sky+ term. For Sky Q it's multiscreen. What is happening with your mini box?
Message posted on 09 Nov 2025 06:26 PM
Re: Sky q
Hi @Mike436
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
