Discussion topic: Sky q still not working
Message posted on 07 Dec 2025 10:14 AM
My sky q box is still not working, I have tried to reactivate, turn it off. It still says there is a problem finding the Sky Q. On the network?
Message posted on 07 Dec 2025 10:38 AM
Re: Sky q still not working
Hi @Tony283
If this is a mini box carry out the following.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 10 Sep 2026 03:32 PM
Hi Iv had someone in tday to my sky q box an it's gone again as soon as we put the tele on I went upstairs to check the main box I'm not even getting any sound from that one I can't be up down the stairs I'm bad on my legs
Message posted on 10 Sep 2026 03:43 PM
Hi how do I get through to someone again please I was on with a colleague yesterday my sky as gone again someone only came out this morning
