Discussion topic: Sky q remote
Message posted on 21 May 2025 10:47 AM
Sky q remote
Message posted on 21 May 2025 11:12 AM
Re: Sky q remote
@Kerriewakely wrote:
My sky Q remote isn't working
First make sure that you have new batteries in the remote.
Then with the Q box on with green led try completly resetting your Bluetooth remote.
Failing this Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
