Discussion topic: Sky q remote
Message posted on 31 Oct 2023 06:47 PM
Sky q remote
I have received a new Sky Qremote but cannot seem to get it to activate. I cannot de activate my old one as it has been destroyed. I have tried pointing it at the box and pressing 1 and 3 but it doesn't work! Please help!
Message posted on 31 Oct 2023 07:21 PM - last edited: 31 Oct 2023 07:23 PM
Re: Sky q remote
Hi @Vicky16 Does the LED light up when you press the "?" key? It should control the Sky Q box unpaired (line of sight). Note there is no need to deactivate the old one as the new new should overwrite it.
Message posted on 31 Oct 2023 07:29 PM
Re: Sky q remote
Hi @Vicky16
You need the Q box on with green led.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
