2
This discussion topic has been answered Discussion topic: Sky q recordings
This message was authored by: COOPER131
Sky q recordings
When I select a recordings it says please wait can take up to 5 mins before recording ready to watch, happening evrry day.
Re: Sky q recordings
@COOPER131
A lot of minor niggles can be fixed by a reboot.
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
@COOPER131
Avatar for COOPER131
Thank you will give it a go later when I get back home.
