Discussion topic: Sky q recordings pausing intermittently on replay
Message posted on 05 Dec 2025 07:57 PM
Our sky q recordings are visible but when I try to replay them they keep pausing and restarting and will not always fast forward. I have rebooted twice but no different. Hard disk issue?
Message posted on 05 Dec 2025 09:02 PM
Re: Sky q recordings pausing intermittently on replay
Message posted on 05 Dec 2025 09:18 PM
I have tried that to no avail 😞
Message posted on 09 Dec 2025 06:58 AM
Turned out to be a hard disk failure on the unit Being replaced by Sky.
