Discussion topic: Sky q problem
This message was authored by: Jonesy63
Sky q problem
  • I keep getting technical priblem message or connecting is a problem resetting box every day
Re: Sky q problem
Hi @Jonesy63 in the following order, try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, do the same with any Mini boxes?
