04 Dec 2023 06:42 PM
Sky Q box keeps turning off completely then restarting during viewing.
04 Dec 2023 07:13 PM
Sounds like it could be overheating. Assume it is not stacked with other devices and is well ventilated.
Does it feel very hot to touch?
They do run warm but not hot.
It it doesn't appear to be overheating
